I was under the front of my 70 Superbee tonight doing a little work and noticed that the passenger side sway bar washer was rubbing on the control arm. Upon further inspection I noticed that the front sway bar brackets were angled different. The drivers side was angled forward where the passenger side was angled back. It appears that by it being angled back it is pushing the bars attachment bolt back to far which is making it hit the control arm. Can someone with a 70 B-body look at the direction that their front brackets angle to confirm this?
