Could you fit a 3.5" pipe in there? Your surface area of a 3.5" pipe is 9.621", while, as previously mentioned, the dual 2.5" is 9.817", so basically a wash as as far as that goes, but you have the advantages of a single pipe (less boundry layer, weight, etc). 3.5" pipe is a little tougher to find but not impossible.
