I think it depends on the motor and on the carb you choose. If the carb is on the small side of what the motor wants yes you can pick up some power. The Carter AFB's were a bit on the small side of what they were advertized. The Thermoquad picks up quite a few cfm by removing the choke and linkage. Dave
