In one situation I had great luck curing a paint job with a propane blow torch
Had to wave the torch around a bit to make sure not to burn the paint right off again, but it went from wet to completely dry/cured in 50* weather in 10 minutes. The water pump still looks great today, a year later
If you ever find yourself in a fair fight, your tactics suck.
