Header thermo-wrap will save you alot of headaches
Actually had that wrapped on there but it it slipped down.
This time I think I'll use this stuff.
I think I'll wrap a spring around the cable in that area too so if it melts again the inner cable won't just push out.
Allen Here's a novel idea, let's not throw a bunch of parts at the car hoping it will fix the problem and instead spend a little time diagnosing it first. Life was a little easier when I was just a wrench.
