Yes, if something went wrong in the seatbelt interlock system and prevented the engine from stating, the red button could be pushed to override the system and allow an engine start ONE TIME....it would then reset and you'd have to push it again for the next start.
The interlock box interrupted the yellow wire that energized the starter relay.
The INTERNET, the MISinformation superhighway
