A manual column is longer. Also, on a 70, the outer steering shafts are different lengths. You can lengthen and/or shorten the column as needed. You'll have to redrill and reinstall some nylon pins to retain the columns ability to collapse. I just did this in my 70 B body. Do a search and you should find the post.
