Bolt hole may be smaller on the early drum LBJ.
If you are doing this, I'd buy fresh 73-76 A body lower ball joints. I believe you can ream the holes in your current lbj if bolt spacing is the same.
71 Control arm likely is a small stud ball joint. You need a sleeve or the large ball joint upper arm.
You can use the lower control arms from your A-body, just not the ball joints. Stop down to your local parts store and grab the ball joints for a 73-76 A-Body. i did this swap on my 72 Dart.
[color:"#00FF00"]68 Fastback Barracuda with some stuff[/color]
