So everything bolts up corecctly inside the bellhousing? Does the trany bolt dirrectly to the belhousing or is there fab work to be done, What clutch fork did you use? What is the 1" thick steel plate for?
Maybee some more detailed instructions for us out there that might want to try this.
Great info though!!
