Hey guys. I have two problems. First, my cruise in my 04 Neon no longer works. The cruise light will go on but once you press set,nothing happens and the light goes out. I unplugged all the plugs to the computer, disconnected the battery for 1 hour and still nothing.
At the same time, the cruise went out, my wipers also acted up. The problem there is when the car is running, the wipers will not turn off. They are in low speed. The arm control inside does not do anything regardless of position or on or off. The wipers just keep going. So I pull the fuse to stop them. On a whim, I put the car in ON position and the wiper functions completely work normal-hi, low, delay, mist but the fluid doesn't come out. What the heck?
Wondering what is going on? Related? Not related? Any help would be appreciated. Thanks.
