Just picked up my small block 340 + .030 from the machine shop after a year and a half. It's a 340 and going together with Carillo rods, Ross pistons, Isky ground .660 lift roller cam, Erson 1.6 roller rocker arms, Batten aluminum W2 heads (mega port and polish), Indy 360-3 intake. Should be at least 14:1 compression ratio. Want to get it together and in my little Dakota so I can run it one time before I get rid of everything. Strip here is closed and doesn't look like anybody has the coins to buy it. I am too old to do a lot of towing so I will be finished if I can make just one pass in the little truck.
