245/45-18 on the hot rod. I would prefer a bit more sidewall too but the tires already rub on the frame at full lock and I don't have any more room to the outside.
The Imp wears 255/70-15 which is a 29" tire. It swallows those tires without any fear of rubbing anywhere.
We are brothers and sisters doing time on the planet for better or worse. I'll take the better, if you don't mind. - Stu Harmon
