The distributer pad
has H 440
Below it a 804 or 8 4
I am just trying to get as much info as possible about the original motor. I am just curious.
I know the motor is a different motor due to the work done on it. It is bored .30 over balanced and has head work with 915 heads. Crane gold 1.6 roller rockers and a bigger cam. It has a performer RPM intake and holley 750 carb, Electronic ignition. It has TTI exhaust with the H-pipe.
such as ???
Its a std fare NON HP low compression 1972 440 assembled on August 4 1971 , had a forged crank originally, it wasn't installed in any performance model , came out of a C barge.
What else would you like to know ?
