Quote: Couldn't I be lean in just the idle circuit though? This doesn't happen unless I'm just within the first crack of the throttle to maintain speed on a slight grade in town. Everywhere else it doesn't stumble or surge at all.
Since you are driving down the road when it's happening, the carburetor is now using the primary jetting. Try going one step larger on the primary jets and the lean surge should go away.
