With the front up 1" set the camber to 0
set the caster to as much as you can with toe at 0
to a 1/16 toe in
Just trying to clarify the above 1".
Is this 1" of body lift or 1" of tires off the ground lift? If it is body lift, where/at what point do you usually measure the body lift? Lift at the rocker panel and lift at the K frame are different amounts. Thanks for clearing this up.
Old Geezer Racing
