Quote: The PROBLEM? While at cruise speed, the engine runs UNDER the stall speed and feels lazy.
Is the laziness due to the stall speed or the cam? I'd say it's the cam. The ultimate stall speed of the converter doesn't say anything about how close it comes to theoretical lockup at cruise speeds.
The factory used some fairly loose converters with axle ratios in the 2's.
