I've always done like A12 mentioned. I've mounted them under the dash. It takes a lot of extra work to cut and lengthen the wires and the re-wrap them afterwards to help blend in, but it looks great afterwards. If you didn't notice the extra wire coming from the distributor then you really wouldn't know it had electronic ignition. When I get home I'll post a picture of the bracket I made.
