I am using the 1977 block, pistons and crank shaft. I am using the edlebrock performer RPM cam, RPM intake and an edelbrock 750 carb. I have the 915 heads from the original 1966 big block that was in the car. The heads have had minor work done to them to update the valve seats. Does this sound like a good combination or would you still switch the cam?
