it's just a matter of being careful when you start the damper on (eyeball the end), i've seen this too many times. when in doubt remove the tool or bolt and check it. with a damper that fits tight you need to be even more careful as you can't tell all that well if it's mashing the key. as tight as some of these are it won't move the damper to align itself either if it's off a little
