I'm 99 percent certain an LA motor will bolt up. As for the poly, I think somebody makes a 4bbl intake. Cam would need to be custom made. As for the bottom end, it's still basic smallblock, so a stroker crank can be done.
Buy a Hybrid!! I need your gas!!! Currently spending $1,000 a month to feed the Hemis!! Looking for that elusive CHEAP 71-72 Plymouth B-body 2 door OR 71-72 Coronet 4 door!!!
