plan on replacing the bearings regardless
As a general rule or from the axles supported w PCV pipe & being moved around
I would just as a general rule if moving it around with no lube and/or support on the bearings themselves
my idea is just to keep the axles from flopping around and should not be used to move the car any farther or faster than you can by hand
