You should be fine. The 727 is a strong trans.
i agree. and as far as the differential, the higher the ratio (low numerically), the larger the pinion. the larger the pinion, the more teeth in contact. and you're talking about a dana 60, anyway. go race!
for what is the good life if not doing things thoughtfully?
