Quote: I currently have a hydraulic flat tappet, but I am open to suggestions as to what type of cam and grind would make a good combination. I want to make the correct choice, and if I need to get rid of what I have previously bought, that is okay.
My cam right now is a comp xe275hl.
I would go to a solid FT cam, maybe?
I have been thinking along those same lines, but i have no idea where to start. Is a f/t very streetable? Also, What specs do I need to know to make an informed cam choice?
You'll need to work with an engine builder to get the right cam. There's never too much info!
