It's connected to the passenger side of the front metering block of my 800 Holley. Is this right or wrong ?
Depending on the metering block, sometimes it ported vacuume, sometimes not. As suggested, just start the engine let it idle and see if theres suction at the port. If there is, maybe another source somewhere on the carb.
When it takes more than a sweet mullet to prove you rule at the trailer park..
