I stock ARP kits here in Syracuse, about $62.00 a set new.
I can also probably scrounge up a set of stock bolts off some core engine for you if you want. Is this just a stock rebuild?
RIP Monte Smith
Your work is a reflection of yourself, autograph it with quality.
WD for Diamond Pistons,Sidewinder cylinder heads, Wiseco, K1 rods and cranks,BAM lifters, Morel lifters, Molnar Technologies, Harland Sharp, Pro Gear, Cometic, King Engine Bearings and many others.
