the two shims inside the pump were .028 and .030. I added .065...not great with math but I believe that puts me at .123. I followed the article as close as possible...
In the original tech article they used the /6 valve assembly which had .077 total shim but in the Feb issue a reader wrote in and said he went up to .110 and it felt great so I wasn't sure how much to try. I don't want to be draining and pulling that valve assembly any more than necessary of course.
Let me know how you like .123 Thanks.
