Ive got full vacuum at idle in my durango. When I put my finger over it I can hear the valve snap inside, but It has FULL vacuum at idle and I couldn't get a straight answer googling things. Would this cause some oil consumption.
That sounds pretty normal....if in doubt just replace the valve(with the correct, quality part)Don't forget to check the fresh air side of the pcv system.
