You are talking about rear-clipping a '70 Challenger? A 1974 rear clip should be the same with the exception of the rear side marker lights, & of course the tail panel. Frame rails should be the same, wheel tubs, rockers, roofline, rear window panel, etc. should all be the same.
No Man With A Good Car Needs To Be Justified
