I have some Rotella Motor Oil sitting at home that was intended for another project. I just so happen to have enough for my next oil change in my WJ. (an '01 Jeep Grand Cherokee with a 4.7 liter). I always run WIX Oil Filters and for the past 30,000 miles I have started putting thicker oil in it (10W40 or thicker). It had developed some valve train noise more than likely from high mileage (140,000 miles).
Would it be a bad idea to use up the Rotella in my WJ for the next oil change? I don't like to change oil brands alot, I have been running the Ford Motorcraft synthetic blend for a couple of years now.
Let me know what you think.
I have pounded the crap out of my 4.7 5speed and have the same problem. I have been using 15w40 mobil 1 and the noise is still there. I don't think the rotella will fix the problem. You either have bend rockers or the lash adjuster is worn out. I would like fix mine but I was quote something like 16.00 for the adjusters and 8.00 for the rockers. Anybody else have any Ideas??//
