'70 Charger. Not Challenger.
If your '69 RR has a basketweave type material in the center of the door panels, then it's the base (Belvedere) interior. Should also have non-plated armrest bases in that case, and maybe no rear armrests.
If the door panels are 2-tone and have horizontal pleats, then you have the Decor/Deluxe/Satellite interior. Might have also had buckets, in which case there will be 8 holes in the floor pan for ft seat brackets instead of 4 for a bench. Obviously no bench with a console.
If they differ from the above examples, post a pic; could be someone replaced much or all of the panels & seats.
Sorry, I had my panties in a bunch and was not reading closely; I have been working on the car today too and the area I'm working with always p's me off as a former owner did a hack job.
I think you are correct though; the grain on the inserts is a match to the 70 Charger. Looks like it is not the original seat. Unfortunately, the door panels in the car are from the same 69 GTX that the seats that are in the car are from.
I know my mom has some pics of when we got the car with the original door panels; looks like that is my next step to figuring out this mystery. I do know that the car was a factory bench seat car and converted to buckets. It also has plated arm rest bases and arm rests in the back seat. Thank you all!
