How many tanks of gas are you going to burn a month through it? My answer was probably 1 and occasionally 2 per month. That's about what my buddies burn through their Mopars, so I opted for the higher compression option. I'll now have to add a few gallons of 110 octane leaded racing fuel to each tank. Another way to look at it, is that for about a dollar more per day, I get to run 13-to-1 compression in my hotrod . With a carefully set-up distributor advance curve and a few extra bucks for racing fuel per tank, I just couldn't resist the throttle response, the sound, and the performance of a 493 inch, 13-to-1, roller motor with a four speed.
You make a very good case that I have never thought about before for just going hog wild with it
