If using the .64 unit.....
run 4:10s...with 27.5" tire you will do roughly 80 around 2700-300 rpm....and more gear will be too much...and less is up to you....
use the overall chart to figure out what you want your cruising speed/rpm range..
1968 Dodge Charger R/T
1971 Plymouth Roadrunner
1998 Jeep Cherokee
