Quote: Not saying its wrong but I have never seen it done like that! I have always painted them with the doors trunk and hood off so the jambs get done at the same time and then spray the clear the same day as the base coat! Looks great and cant wait to see it finished up!
I normally spray all the jambs and that stuff as I spray the base then move to the exterior and shoot that... then go back for the second coat on base... that includes doing the jambs again... then set up for clear... doing the jambs first again... what I remember is that you have (I believe) 48 hours to shoot the next coat or you need to scuff it so it has bite.... but in his case he is wet sanding so that will be giving it the bite
