Gary I do run water to the center of the heads as well in between the exhaust ports. You can see the lines one photo under the header. You do not have to use AN line just will need a tee it you only have one outlet as I do. I already had the fitting on the radiator from when the Hemi was in the car. You could simply make a tee with slip on hose.
