The goal was to add a full cage to the car, and this is the thread where I will be talking about it. The cage is being installed by MW Racecraft, out of Coon Rapids, MN. http://www.mwracecraft.com/ The cage is a 10 point if I don't end up installing the front bars, or a 12 if I do install the front bars. The goal here is to be able to use the entire interior. Rear seat, side panels, door panels, even the factory headliner AND dome light. Big order? I would say so. Granted the carpet will have to be custom, and I have to modify the dash some for the A pillar bars, being as I must be able to remove the dash once the cage is in place. Keep in tune for more pictures as the build progresses. Here are some pics.
the subframe connectors
so far the back of the cage has been mocked up and tack welded in place.
