Speaking of the oil lines are u guys running the 0.40 restrictors...i did not and to much oil up in head and the vacuum pump tank filled up in one pass....and overflowed..installed a baffle in the valve cover and moved the fitting to the front of the valve cover...any other secrets???? sorry for jumping on thread pattyboy
I never did with indy rockers...I do with spray bars though for T&D rockers.
