WHAT SIZE CABLE DID YOU GUYS USE?
I found some 2Ga american made welding cable tonight for $2.09 a foot. I was thinking about picking up about 10' of for a ground wire. I wasn't sure if I should use a heavier gauge wire for the positive cable from the battery in the trunk to the starter or not. What do you guys think?
I used a piece of #1 for the positive and two # 2 in the trunk for the grounds, I also use two or more #4 grounds to the frame from the engine as well as the aluminum elephant ears. You can never have to many grounds on a race car with the battery in the trunk ![](/ubbthreads/images/graemlins/Twocents.gif)
