Both of those air cleaners were cut to clear the A/C line on the back of a OEM compresser. You had to do this when you tried to use a sixpack setup on a AC car or vice/versa. That aircleaner was NEVER used on a A/C car from the factory .
Mike,that one came right out of an old Direct Connection box in the early 80's,not on the car now but I still have it.
