the FSM says 0, TDC.
if it is relatively stock i would start at about 12 BTDC and just keep going from there. total is more important though, and 32-34 is most likely what it will want. but they will take a lot of initial, just depends on the curve of the distributor as to how much initial you can give it and still end up with the total that you want.
