one would have to make some assumptions as to chamber size, valve reliefs etc. but lets say you had a 77cc chamber and 4 cc's of valve relief and your piston was down .05 on the 10-1 combo, adding .05 to make it zero deck would make the compression ratio 11.167-1
machine shop owner and engine builder
