Re: Applying Decals!
[Re: Boot]
#115536
09/05/08 04:19 PM
09/05/08 04:19 PM
Posts: 12,043 State of Confusion
hp383
Just a normal tag again
State of Confusion
and it wont remove your wax either
True, but you want to remove the wax if you want to keep the decal. Just like paint, the decal is only going to stay if the surface is clean, and free from wax, oils, and dirt.
The windex method works really well, just dont go nuts with the windex. The decal will sort of float around until the excess is squegeed out, and wont get full adheasion until the last of the windex has had a chance to dry, and evaporate.
The soap and water method works well also, just remeber a drop of soap in a full spray bottle wil do the job (less is more). But you will need a wax, and grime remover first.
Join the Penguin Liberation Front!! Stop the Hippo Occupation!
