what size tires are you running on your street strip a bodys this is a big block we are currently setting up the cap tubular k frame with a front mount rack and pinion have 195 x65 15 and are having clearance issues at the frot edge of the fenders thoughts and suggestions welcome
Figure out what front size and width tires and rims you want to run and then trim the fenders as needed I could run 26x15 inch tall M/T front runners on four inch wide rim (1 7/8 rear offset)with no problems on my 1971 Duster with stock,uncut front fenders. I bought a set of Moroso 7.10x15(27 1/4 hieght) and mounted them on a set of Centerline 4x15 rims with 2 1/8 rear offset and had to trim the front edges and remove two of the inner fender bolts bolts that hold the inner splash shields in the fenders Your call BTW, the front ride hieght plays a big factor on which ones fits and which ones don't
