wiring looms I know are longer on E-bodies but for the life of me can't remeber if originals were 7 or 9 hole.
battery to radiator support ground bolt is clear zinc not body color
master cap I think was originally dark grey phosphate on 71's with drum brakes.
Also, in regards to the horn bolts, I've seen both these dark bronze AND black phosphate plating on originals . so imo, both would be correct.
Thanks! Im not 100% sure but i think its 7-holes wire looms for the horn wires.But i dont know where to get them..
From my research on 71 cars the wire loom is the shorter 5 hole by the horn.
