The HS are a little long on the RPMs, the rocker tip will run outside of center on the valve tip. IMO, it is no big deal.
I'm using the Comps on my roller cam street car with no problems. I think any of those choices are fine if the new Cranes are the same quality as the old Crane Golds.
Not perfect but w/lash caps, 7500 rpm shifts and 7+ years later they`re fine and my guides were perfect..........
72 Dart 470 n/a BB stroker street car `THUMPER`...Check me out on FB Dominic Thumper for videos and lots of carb pics......760-900-3895.....
