Can you raise the front end (turn torsion bar adjuster CW) with the tires on the ground, or will it snap the bolt? I started to do this and then realized something was going to give. I'm wondering if I weakened the adjuster bolt.
Never raise it with the suspension fully loaded... I've learned that the painfull way! Even though I had cleaned the threads and put some anti seeze the threads sheared in the retainer and snap the ratchet out of my hands so fast that it teared my skin on my finger just by the friction of the smooth ratchet handle... Never again!
