this is how we learn and get it close as possable with used parts.
I have done it more than one time,now to really fine tune it you can play with the levers at the trans longer shorter and some have the D-hole clocked different to help.
it has room for adjustments from the looks of it in the pics
and thanks for posting them
mucho help to see it from here
if needed useing another flat slide bar bolted to the one you have to make it longer is an option if need be to fine tune it..may need a good bend/tweek here or there also.
haveing it hooked up is the main thing to start with.
I give it a pass and check off the list,on to next item on the road ready list
whats next on your hit list?
we need more pics
here in FL they sell pine needles for 4.75 a bail
