I pulled the tail and "think" the leak was coming from the low band apply lever shaft. It has an O-ring and think that was it.
But at least all the lower tail bolts go right into the main case and are wet so I'll make sure I put a little goo on the threads when I put it back on.
This way all the bases will be covered.
2017 Contusion Blue Challenger T/A 392 M6 "BLKNBLU"
