Hoping to fire the fresh built 318 this weekend:
I have Autolite 85's in my DD 318. Made in China now I understand. Any stock heat range will work for you. OT might read "breakin secrets" at www.mototuneusa.com (5 minute read) (30 minutes if you read at DogDays' comprehension level) EDIT the #1406 is lean, might go up 1 jet size (from 95 to 98 iirc) MORE EDIT I may be thinking 65's (& I just pulled one yesterday)
