Man that is real good!
Do ever work on Big Blocks?
I just bought a set of W9's and with those kind of numbers you could make some serious power. I was going to build a 440 small block, I might have to rethink that and go a bit bigger.
I would really like to get those kind of number out of a set of B1-BS heads.
B1-BS head doesn't have a tall enough port for that kind of flow. Only so much you can do with a standard port height. Better capability with the Victor head or the Indy EZ due to the raised port.
It would be nice though, standard height intake port and that kind of flow? It'd surprise the crap out of folks.
