I have a 451 indy sr heads solid roller,I have a 850 demon.What about a 1050 dominator.Its a street and strip car.Thanks
If you max the tune up on both carbs the 1050 should be 1/10 to 2/10 faster and probally 1 to 2 MPH faster Mine is a street and strip car pump gas car that runs in the low tens and one high nine so far Edited I have several 1050 Dominators, three early 9375 non HP and two later 9375HP. One of the early 9375 was converted to annular boosters, it runs the fastest on the car I'm working on the part throttle cruise AFR now,it was really risch to begin with I have been leaning the part throttle fuel feed and idle fuel feed( a little bit at a time) to lean it down according to the wide ban AFR meter,it has been a challenge I'm at around 12.3 to 12.8 (it started at 11.3 )now and shooting for 14.2 or leaner at 2000 to 2500 RPM cruising at real light throttle
